gmpp head bolt history?
Old 06-28-2011, 06:31 PM
diablizzard's Avatar
Default gmpp head bolt history?
has any body had problems with the GM Performance parts head bolts not being able to hold any torque. I was just trying to torque them down at 65 ft/lbs and they were stretching. I even used one of the flexing wrenches to watch it. and it wasn't making it to 60. before any body asks, I did step it up in incriments. I've used them before on my truck engine, and that was at 80 ft/lbs. this is about my millionth issue with this project.
Old 06-28-2011, 06:33 PM
speed_demon24's Avatar
Were they new bolts?
Old 06-28-2011, 07:38 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Are you saying you've used these bolts before and they were torqued to 80 foot pounds and you're trying to use them again?
If yes, they were junk when they were torqued beyond 70 foot pounds.
The max on a stock bolt is 70 foot pounds. They will stretch at not much more.
You shoulda went with the insurance of ARP head (and main cap) bolts.
http://www.348-409.com/torquesm.html
Old 06-29-2011, 10:28 AM
GIZMO's Avatar
The GMPP bolts can be tourqued one time only. After that they are garbage.
Old 06-29-2011, 11:00 AM
Mystery Bird's Avatar
I've had brand new ones break before I hit 65 ft lbs. a year ago on a project. They did do a warranty claim...for one bolt!!! Junk!!! I've switched to ARP and never looked back.
Old 06-29-2011, 12:12 PM
It was definately brand new bolts, especially since I'm hoping to make some serious power. When I said I used them before, I meant that I used the same product before. GM is going to owe me some head gaskets, I'm not paying for those again. I'm definately going to arp after this. They better not pull a one bolt BS.
Old 06-29-2011, 12:55 PM
Paul Bell's Avatar
I doubt if GM is gonna return your money for head bolts let alone replace the head gaskets for free.
I guess this was issue one million one, eh? Get ARP bolts, new gaskets and don't look back.
Gizmo, good (SBC) head bolts should be able to be re-used. They are not TTY like in the LS series.
Old 06-29-2011, 02:15 PM
This is true, the place I purchased them refunded my money for the one bolt.
Old 06-29-2011, 02:16 PM
I'm hoping because I'm using cometic gaskets. That'll add another 270 to my project bill with the bolts, which I can't spare right now.
Old 06-29-2011, 04:09 PM
Paul Bell's Avatar
Cometic gaskets can be re-used.
Old 06-29-2011, 04:57 PM
That is a huge relief. I thought once all headgaskets were torqued that was it. I found a set of arp headstuds brand new in the box on ebay for $90. I'll just move on and continue then.
Old 06-29-2011, 06:09 PM
TheHeadFL's Avatar
Is the engine in the car? Watch out with the studs... I've heard its near impossible to get the heads on in the car.
Old 06-29-2011, 06:31 PM
Paul Bell's Avatar
It's easy. The studs go in after the head is laid on the block. They have a internal hex. Spin them in with an Allen drive socket then washers & nuts. Torque. Beer.
Old 06-29-2011, 06:37 PM
beer is good. thank you for all the advise every body
Old 06-29-2011, 08:57 PM
GIZMO's Avatar
I am pretty sure that he is talking about these. If not, then I stand corrected.
Old 06-29-2011, 09:07 PM
96capricemgr's Avatar
Best we can tell LT1s came with both standard and TTY bolts over the years. Would be pretty typical for GMPP to supersede a PN and substitute the later ones when folks order for an older application.
I would not go putting studs in a block bored with bolts.
Old 06-30-2011, 10:42 AM
sweetbmxrider's Avatar
Head studs are prone to coolant leaks, watch out.
Old 06-30-2011, 01:31 PM
wouldn't I just put thread sealer on them?
I don't understand what the differance would be, except how they get threaded on.
Old 06-30-2011, 02:38 PM
shbox's Avatar
That's what most people try to do, but end up with leaks for some reason. Better search for what people say works for sealer. IMHO, use studs only if it is something you must do for build reasons.
Old 06-30-2011, 06:42 PM
The distortion to the block once torqued is different with studs vs. bolts. Best to stick with whatever fastener type and torque spec was used during machining.
Quick Reply: gmpp head bolt history?
