Do I run any risk removing the front sway bar and does it help at the strip?
I was thinking of removing the front sway bar to take some weight off the front end, but I was wondering if its going to make any difference at the track whatsover? Also, if I was to leave it off all the time, will I run a risk driving it around town or sometimes on the highway? I dont do any high speed corning, road racing, etc. The only time I speed in it is when the road is straight. If I come to a curve in the road, I usually slow it down because I run race wheels and tires. Thanks.
The sway bar itself only weighs like 5 pounds. Removing it for the track is good because it will give you better weight transfer by letting your front end rise more off the launch. Driving around normally, just don't play race car around hard turns and don't make any crazy maneuvers. You should be fine otherwise I've had mine off for forever.
I believe the front sway bar is hollow. I'd guess it weighs more than 5lbs too. There are other things you can remove before that, such as the spare tire and jack, and the back seats.
[Edit]: According to the "Weight Reduction List" the front sway and brackets weigh 14 lbs. I still think other things can go first...
Originally Posted by Jpr5690
but what if ya have so swerve to miss a deer or whatever then your fucked without it
so I dont have to worry about it anyway
Without a front swaybar to control body roll, if you get that car even a little bit sideways, it's going to be EXTREMELY difficult to get it back under control. I've seen cars on the dragstrip itself that have gotten sideways and literally fishtailed half a dozen times before getting it back under control, and on several of those cars I knew for fact they weren't running a front sway, and the way the others were rolling back and forth it looked pretty obvious they weren't as well. It's bad enough having that happen on the track. Risking it on the highway or side roads, and you're just asking for trouble.
