Master Cylinder Templet
Old 06-29-2011, 01:09 PM
Gordon0652's Avatar
Default Master Cylinder Templet
Doing an A4 to M6 swap for my T/A. Any one have a templet for drilling the three holes? I will be using Tick's master cylinder which bolts up to factory location.
Thanks!
Old 06-29-2011, 02:12 PM
ssdeuce74's Avatar
i would think gm had something on the firewall to show where they go i didn't think they had different firewalls auto to m6, i don't know but most manufactures work that way, indents, spot welds something
Old 06-30-2011, 12:38 AM
RedRallyeZ's Avatar
if youve already gotten the M6 pedals, they actually frame the area quite nicely. There are two bolt holes in the pedal assembly that make it very simple to mock up a piece of cardboard or something.
Old 07-02-2011, 02:02 AM
oldmano2z's Avatar
gordon, the stud on your firewall that held the auto pedals in place might need to come out. mine did because of the size of the block the master was bolted to.the pedals locate you close enough to drill your holes.tic is the greatest..
Old 07-02-2011, 09:53 AM
Gordon0652's Avatar
Thank you for all the help, i did look at the pedals and i can see it now. Have not looked at the pedals in a long time - installed a year ago..
Quick Reply: Master Cylinder Templet
