Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
ford 8.8?
Old 06-29-2011, 04:20 PM
black04silverado's Avatar
Default ford 8.8?
Has anyone made the brakets needed for the swap yet?
i know i heard of someone trying to but never seen any more on that.
Old 06-29-2011, 04:36 PM
lilgcts-v's Avatar
yup, creative steel !!!
Old 06-29-2011, 04:38 PM
any link to where i can but them?
i have an 8.8 center section just need the brakets to install
Old 06-29-2011, 06:11 PM
NeverSatisfied02's Avatar
I know a local guy had an 8.8 setup he was working on. He said he had it pretty much all mocked up... just needed to play with the install. Not sure if he ever did it or not but id be extremely interested in this as i can get an 8.8 for rather cheap.
Old 06-29-2011, 06:18 PM
i got one for next to nothing. (i work at a ford dealer)
Old 06-29-2011, 06:21 PM
Nice! I just know a lot of guys in the mustang scene. I could get my hands on one pretty easy too.
Old 06-29-2011, 06:25 PM
so all i need is some way to install it and axles and i would be set.
Old 06-29-2011, 06:47 PM
If creative steel really makes a mount kit, that would be nice! Im sure axels wouldnt be too bad. Wonder if someone makes them in the proper length with the V's 6 lug pattern. I wouldnt mind doing a 5-lug conversion on mine just to get some more wheel options.
adanieljohnson1's Avatar
Hmmmm.... you should do burnouts until you bust the current one and then do the swap! Get vids! Hehehe
Old 06-29-2011, 06:50 PM
Once i have everything i need to do the swap... I'd do it... lol
Old 06-29-2011, 07:11 PM
idk why nobody has not already made a swap like that the car has been out 12 years.
if i had any fab skills at all i would try and make one work.
Old 06-29-2011, 07:54 PM
lilgcts-v's Avatar
just call creative steel
Old 06-29-2011, 10:09 PM
i sent them an email we will see what they say.
killernoodle's Avatar
I'm still working on a kit as well. Got like 10 projects going on right now lol.
Old 06-29-2011, 10:12 PM
I wish it wasnt so hard to make fit.
thank you gm for another shitty rearend
Old 06-29-2011, 10:45 PM
Fuzzy_Wuzzy's Avatar
Even if you needed custom axles, DSS should beable to make them fairly easily, you could reuse your stock outer CVs, (or buy a set of their race outer CV's) I am sure they have a sed of inner CV joints for a ford 8.8 with whatever spline size you have (or use a stock inner CV) then ask them how you should measure for shaft length and tell them what cv's you will be running on either end so they can size the shaft for you.
For the pose above about lug pattern, IRS cars arenot like solid axles, there is a seperate hub that stays the same that has the wheelbolt pattern on it.
Old 06-29-2011, 10:52 PM
itsslow98's Avatar
unfortunately with this typ of swap its not the diff thats the expense, its the custom axles and brackets and welding that adds up. Realistically i dont see it being much cheaper then any premade kit. Just cause its an 8.8 doesnt mean its bulletproof. you still have to build the internals of them to handle the abuse.
Old 06-29-2011, 11:17 PM
i know it wont be bullit proof but its stronger than what we have now, and i do plan on building the internals to handle what im gonna throw at it.
and well if it breaks i can get used 8.8s all day cheap.
so to me at this point its more cost affective to go this route.
Old 06-30-2011, 11:16 AM
johnrowdy's Avatar
I like this idea!
Quick Reply: ford 8.8?
