Vibration in gas petal...
Old 06-29-2011, 05:35 PM
thegodfather899's Avatar
Default Vibration in gas petal...
Hey guys,
i kept getting a weird vibration in my gas petal when i ran it hard or dumped the clutch a little more than normal only in 1st gear. i changed the clutch (which had burn marks on the pressure plate), slave cylinder, and clutch master cylinder. After put together again, i still have the problem mostly in the gas petal when i dump the clutch a little more than normal. it feels like something is slipping or rubbing. I also feel a little vibration in the clutch petal under normal driving. Are these two related? any ideas? Thanks!!
Old 06-30-2011, 10:47 PM
anybody have a clue?
maybe throw out bearing or unbalanced clutch/flywheel or something?
Old 06-30-2011, 11:56 PM
mob_barley's Avatar
got the same problem, although i seem to have other tranny problems too...
Old 07-13-2011, 05:37 PM
turns out the vibration was a bad pilot bearing in case anyone has this problem
