Help! I've Searched! 4L60 to T56 Cruise Control
OK I have read almost every thread on LS1TECH and cannot find any more information, and my Cruise still doesnt work. OK backround, this was a 2002 Auto 460E, that I converted to a T56. I swapped the Auto engine harness with a Six speed harness so everything plugged in right! but the BCM is still an auto. So the 4 wires are ran correctly under the dash for the clutch switch, hatch and back up lights they all work. I have the 1 Clutch switch that is the safety switch that wont let the car start unless its depressed. I do not however have the Clutch antisipation switch. So to my understanding with all that I read Pin #32 on the PCM is the switch and what the computer is looking for, and its looking for a ground in order for it to be active. So I grounded it. Now once I did that DFCO started kicking in but still no cruise. What am I doing wrong?
If i remember correctly, the clutch anticipation switch is normally open and It grounds when clutch depressed to turn cruise off. So if your grounding it its telling cruise to dissengage.
OK I get that, but DFCO only works when its grounded, and even if its not grounded the cruise still doesnt work. So I am almost back to square one, and the cruise still doesnt work. Someone has got to have made it work some how!
