Conversions & Hybrids - Custom length spark plug wires?
View Full Version : Custom length spark plug wires?
Marcello7x
06-30-2011, 01:25 PM
I cam across a thread a day or two ago mentioning a cheap set of lt1 plug wires that were cut to fit that would work for ls engines. Anyone know?
OR better yet whats a wallet friendly set that comes cut to fit. I have stock truck wires, and can use those, but figure while im working on the harness i might as well relocate the coil packs now.
STEEPSS
06-30-2011, 01:53 PM
caprice wires work IIRC
LS1NOVA
07-01-2011, 09:28 AM
Yes the LT1 distributor cap boots work with the LS coils. I buy sets from Jegs for an LT1 car (Camaro, Corvette, Caprice, etc). You can shorten them by buying a new set of terminals for the plug ends but on a friends turbo Camaro they worked as is with creative routing.
LS1MCSS
07-01-2011, 11:36 AM
I do the same thing. Get LT1 wires and whatever spark plug end you want.
Rick364ls
07-01-2011, 11:43 AM
if i am correct wires from 97 up votec have same ends too
Marcello7x
07-01-2011, 01:03 PM
Awesome thanks guys!
After looking on jegs for a bit i saw these. They have a 90* on both ends, may help better with hiding the coils and tucking the wires tighter to the block if running under the headers. Wish they were a darker color tho.
http://www.jegs.com/i/JEGS-Performance-Products/555/40206/10002/-1?parentProductId=1064786
Marcello7x
07-01-2011, 01:08 PM
I guess the main question would be will those boots fit the ignition coils?
Edit: it seems that if they offer different boots for LT. that the normal ones won't fit. Please correct me if im wrong!
TomM
07-01-2011, 01:11 PM
Those won't work, check the applications, they are for 67-86 Chevy vans and trucks......
T,
