no spark.
no spark.
So I just had my ignition replaced 3 months ago and my car has been running great until last night when I went to go start it in the rain the starter turned but the motor wouldn't start. I immediately thought it was another opti but i just replaced that not too long ago and when I hooked a plug up to the coil with a different type of plug wire I got nothing when I grounded it to the headers and had my girlfriend turn it. any easy way to check if it's the coil or ignition?
Also, giving it gas usually changes the speed the motor turns over at but it doesn't anymore. what are the chances it's an ECM('93)?
after doing some research I found that a bad opti can cause no spark from the coil too. I don't really understand how this is possible. does anyone know a good diagnostic procedure that will tell me if the problem is my computer, icm, coil opti or just an O2? this is driving me crazy... I hate electricity
The Opti provides two signals to the PCM, they have to be there. The right and left side are with you sitting in the driver's seat. The O2 sensor has nothing to do with it starting.
Al 95 Z28
Al 95 Z28
