Trans hitting tunnel under hard accel.
Old 06-30-2011, 04:42 PM
ikswelborwnayrb's Avatar
Default Trans hitting tunnel under hard accel.
Just picked myself up a long time coming 2000 WS6 TA and love it. Has usual mods, cam, headers, etc. When i punch it the trans or driveshaft hits the tunnel? Wondering if anyone else has had this problem? Hasn't cause any major problems yet but figure i should get it taken care of before it does. Car has aftermarket steel driveshaft with loop and a S60 for a rearend. Crawled under there and didn't see anything alarming at first sight nor did i even see a mark where it would be hitting. Im 99% positive that i have the right location or close to but can't see all that well and figured id give a shout out and see if anyone has had a similar problem before i just go shooting in the dark? Thanks in advance.
Old 06-30-2011, 05:26 PM
TransWS6Am's Avatar
check your tranny mount, and make sure everything is tight there.
Old 06-30-2011, 05:51 PM
heavy6.0's Avatar
replace your torque arm bushing that should take care of it.
Old 06-30-2011, 05:59 PM
quickslow's Avatar
Default No
You riped your trans mount in half I did a couple of them . get a poly instead of rubber
Old 06-30-2011, 06:10 PM
TransWS6Am's Avatar
I didn't even think of that, that could very well be the problem.
Old 06-30-2011, 09:54 PM
Trans mount is an obvious one that looked good but torque ARM I didn't think of .....thanks ill check that out ASAP
Old 07-05-2011, 11:11 AM
68chevypu's Avatar
Sorry to ask, but are you sure its the transmission banging? Could it be the y-pipe?
Quick Reply: Trans hitting tunnel under hard accel.
