Anyone running AFR 205's with the SS HT cam?
Old 07-01-2011, 03:43 PM
Rise of the Phoenix's Avatar
Default Anyone running AFR 205's with the SS HT cam?
I'd love to see if anyone is running this combo, and if so, what kind of numbers your putting down. I would think this combo would be close to 450rwhp with a ton of torque down low. Please post up if you've got it or know someone who does.
Old 07-02-2011, 02:49 PM
indigows6's Avatar
^^ x2...
Old 07-02-2011, 04:06 PM
Camaro99SS's Avatar
I'm collecting the parts for a h/c swap and will be running a cam very similar to it on an EPS grind, but with about 2 deg. more duration on both sides and from EPS. If I could just find some decent AFR 205's, I'll about be there...
Jason
Old 07-04-2011, 03:15 PM
Jason
I had a set, but traded them, and a custom ground Ed Curtis cam for a set of Fikse wheels.
Old 07-04-2011, 03:28 PM
Cold Zero's Avatar
If you still didn't buy the heads .. just FYI no more AFR 205 .. the new art is AFR 210
I think AFR heads work best with AFR cams .. on M6 car with afr 224/228 the average dyno result is 440 ~ 450 rwhp with nice tq curve
Old 07-04-2011, 03:36 PM
Yeah, I'm aware of that, but will likley try to find a sef of AFR 205's used. That's what I did before. Ed Curtis is the guy behind the SS HT cam and he knows his ****, especially with AFR heads. I'd love to get the SS HT, but on a 110 LSA.
Old 07-04-2011, 11:40 PM
Cold Zero's Avatar
What's the spec oh SS HT cam ??
If you will get a used set of AFR 205 .. Do you plan to send them to Tony Mamo for a mamofied set of AFR 205 ??
Old 07-04-2011, 11:58 PM
indigows6's Avatar
SSHT is 228/232
Old 07-05-2011, 10:08 AM
Probably not. Maybe down the road I would. I'm also thinking about a set of the Trick Flow 220 as cast heads. Could get a brand new set of them for the same price as a used set of 205's.
Old 07-05-2011, 10:20 AM
ZGLASS's Avatar
http://forums.corvetteforum.com/perf...ers-c5z06.html
This is with ok header/cats Cali 91 gas and a safe tune on a load bearing dyno. Will be getting a dyno from a second place to see what it will do. But it runs like a rapped ape!
Old 07-05-2011, 03:39 PM
Thanks for the post. Pretty good numbers. I see that was a Cam Motion grind. Heard good things about them.
Old 07-05-2011, 05:00 PM
ZGLASS's Avatar
better gas, some 1 7/8 kooks or American Racing headers, more aggressive tune and a dyno jet probably closer to 470-480.
Old 07-05-2011, 05:02 PM
ZGLASS's Avatar
you will love the cam with either sets of heads. I like the as cast cause they are almost a budget price. They can also be ran through the 235cc cnc port I heard if later on you go bigger cubes. But 205 afr's are right there with the best of them! Cant go wrong either way.
Old 07-06-2011, 02:09 PM
stanggreg90's Avatar
I was the one that did the trade with rise of phoenix , it was 205 afr heads 62cc and the custom ed curtis cam. Just got the car done made 442 to the wheels with 30 pound injectors , stock ls6 intake , hooker long tubes, hooker exhaust, on a pretty much basic tune. with fast intake, 90/90, pulley , merge should make around 495 i hope
Old 07-06-2011, 03:12 PM
ZGLASS's Avatar
fast will probably get you another 15 maybe 460-465 no way your getting 495.
Old 07-06-2011, 03:18 PM
stanggreg91's Avatar
what else can i do to get like 480 ?
Old 07-06-2011, 03:32 PM
What's up Greg? How was the install? Sound like it all went well. I bet if more time is spent on the tune, you'll be right around 450 or more. A FAST intake and TB will definatley help. What size head gaskets did you use? Also, how was the PTV clearance?
Old 07-06-2011, 03:35 PM
ZGLASS's Avatar
I wouldn't get stuck on trying to hit a number. 480 is not easy to hit with a 346 unless everything is geared to work together. most were thinking mine would do closer to 470whp but it didnt. Lots of variables come into play. But my cars runs like a rapped ape and is snappy and has great torque so i am happy for now. I will re dyno on a dyno jet if i want to see bigger numbers.
450-460 with a mild cam is going to be a fun *** car!!!
Old 07-06-2011, 03:40 PM
What type of dyno was that on Greg? Also, you got an idle video of it. I'm glad we did the trade, but I bet I'll be regreting it once I hear that beast lope.
Old 07-06-2011, 03:43 PM
ZGLASS's Avatar
also is that number STD or SAE?
