PROJECT-"Slowly but Surely"- Input Appreciated
Hey guys,
I'm new to the forum but not to the LSx scene. I have a 98 Camaro with a V6 and a 2002 Z28 that has been in an accident but was "repaired".
Long story short, I bought the Z28 because it was cheap and it runs fairly well. It has 164,xxx miles on it. I was planning to fix it up and drive it, but once i got it up on a lift, I noticed that the "repair" job wasn't all that great. So, I got to looking around for a V6 car with a blown engine and I found the 98 that I have. I'm planning to use whatever I need off of the Z28 to put a built 6.0 in the 98.
I was gonna use the LS1, but I picked up a LQ4 for free. It ran when it was pulled, it just smoked a little. My plans are for a 450-500rwhp daily driver. With the setup I've been contemplating, I should be pretty close.
Now, on to the details.
-LQ4 block, crank, and rods.
-ARP 2000 rod, main, and head bolts
-4.030 Mahle pistons with -4cc valve reliefs
-Patriot CNC ported LS6 heads (2.08/1.60 valves, 64cc, 227cc intake runners, etc)
-.040" head gasket
-LS6 intake until I can afford FAST 92/92 or 102
-Ported oil pump
-Performabuilt LV2 4L60e w/3500 stall
-3.73 gears (salvaged from Z28 until I get a new axle)
-Cam specs 235/240 .648/.609 113lsa on 111.5 centerline
-LT headers
-3" exhaust
I probably forgot a few things, but that is it for the most part. Once the car is put together, it will be getting trailered to Thunder Racing for a dyno tune.
I played with this setup on Desktop Dyno and it came out to 555hp @6500 and 530lb ft @4500. Not sure how accurate DD is, but if it's anywhere close to that at the crank when it's all buttoned up I should be really close to my goals in rwhp.
Let me know what you guys think. I'm open to any questions, comments, or concerns.
-.040" head gasket
-Ported oil pump
-LT headers
-3" exhaust
black00ssFL- I plan on balancing it, that was one of the things I forgot to mention. Why a larger stall?
tomstark- My uncle is good friends with someone that owns a towing service. He had a pickup that had an LQ4 in it, he fired it up and it ran good it just smoked a little. He pulled the engine to rebuild it, then lost interest in it. I asked him about it and he said I could have it for $300. Then a couple weeks later, after my uncle told him I am in the military, he told me to just come get it.
Other things I forgot to mention...
I'll be adding a Racetronix fuel pump and wiring upgrade. I figured up the compression ratio with the -4cc pistons and 64cc chambers with the .040 head gasket and it came out to 10.78:1
Next things to do after this is complete is rear axle upgrade and full suspension upgrade... then a paint job... but that stuff can wait...
I'll just have to baby it until I get a new axle...
Has anyone had any experience with the heads I mentioned? I've read some pretty good reviews, but haven't actually talked to anyone about them... Thunder Racing says they're pretty good...
Here's a few pics of the 98. It's a little rough, but it isn't rusted anywhere. Only paid $800 for it. Needs a front bumper cover, front right fender, interior replaced, has a dented area on the left rear quarter where it looks like something fell on it, and needs a LOT of cleaning up. Shouldn't be too hard to fix though.
