Small Block & Big Block Chevy Specific - distributor gear q?
View Full Version : distributor gear q?
diablizzard
07-02-2011, 09:00 AM
this is for the engine in my truck. I previously had a mildly modded 350 with a hydro roller cam installed. with that I got the correct dristributor gear to match. The motor took a turn for the worse, and I'm putting a stock motor back in for now which has a tappet cam. I can't remember for the life of me remember what I did with the old gear, and when I look for a new one they are for roller cams. would really matter if I didn't switch back? I'm understanding that one is softer than the other to prevent damage.
blk/slvr02ss
07-12-2011, 04:09 PM
Bronze gear for Billet Cams and a Steel gear for Cast Cams ! I think u can use a Bronze on either one should b OK but not the other way around.
mrdragster1970
07-12-2011, 08:33 PM
A mild daily driver that will see thousands of miles needs a stock gear.
