Dyno guys, please come in.
I dyno'ed a car today on the dyno I normally use that reads about 10rw lower than other dyno's in the area. The car put down 425/407rw but it is the weather data that has me confused.
The data it read, Temp 93.7 F*, Baro 30.01 inHg, Humidity 29%. The humidity I knew was wrong. So I looked up the weather data from about a mile away.
Actual data, Temp 85 F*, Baro 30.08, Humidity 57%. I can see it being hotter inside than the outside temp due to the running cars and no air circulation but the humidity has to be the same as out side.
The question. If the weather data or humidity data was correct would the car have made more or less power on the dyno?
