2004 GTO no power with new battery
Last week sometime i noticed the car was having some trouble starting and then cranked up. So a day after its totally dead.I replaced the battery and only heard fast clicks...then the radio lights and everything was dead again with the new battery so im obviously missing something.Any help would be greatly appreciated
Check any major grounds....but the new battery rules out a bad alternator, unless the battery was dead when you picked it up.
Try jumping the car, if it loses voltage and dies, then its the alt, if not its a ground or wire somewhere.
i do believe if you can get it to start and pull the positive off the battery and the car dies its you alternator and make sure you scuff up the post to to get a good connection.....always take it to the parts store and they can test uor battery and alternator
hope this helps
hope this helps
