will an lt4 work in a camaro
Old 07-03-2011, 12:15 PM
LigHtEmUp01's Avatar
Default will an lt4 work in a camaro
i can get my hands on a complete lt4 with computer from a 95 vette and was wondering if it will work in my camaro. i think i might have to put my accessorie brackets from the lt1 on but is there anything else?
Old 07-03-2011, 12:36 PM
1995blacktattop's Avatar
not sure what else you'll need but GM put an LT4 in 100 special 1997 30th ann Camaro SS's so i'd say yes you can use it in your car.
Old 07-03-2011, 12:40 PM
forgedlt4's Avatar
as far as i know, with all of the major parts, everything is a direct swap
Old 07-03-2011, 01:02 PM
shbox's Avatar
An LT4 did not come in a 95 'vette. Better be sure what it is.
Old 07-03-2011, 02:02 PM
yeah i didn't even notice that in his post. i wonder if he meant 96. that was the only vette that had it, 96 6 speeds.
Old 07-03-2011, 03:32 PM
95FbFormula's Avatar
maybe he ment LT5 lol going by his sig though i cant imagine an LT4 would be much better then what he has
Old 07-03-2011, 03:47 PM
Village Troll
SS RRR's Avatar
I took it as meaning the pcm itself is from a '95.
Old 07-04-2011, 01:30 PM
i was told its an lt4 out of a special edition vette with a 6 speed thats im not sure on year but since it was a 6 speed i dont think the pcm will work with my car. im looking to swap it because i wanna get rid of the car and save my lt1 for another hot rod.
Old 07-04-2011, 01:36 PM
the_merv's Avatar
1996 Car..Collectors Edition or Grandsport. That ZF Trans is expensive to work on..
Old 07-04-2011, 03:29 PM
97Z28SS's Avatar
Hell I'd keep the lt4, zf 6 spd and pcm and use that in your other project.
Old 07-04-2011, 03:31 PM
Lawhead's Avatar
Make sure the intake just isn't painted red if that was the case about 50% of LT1s can be mistaken for the LT4 because of the intake.
Old 07-04-2011, 09:45 PM
NewOrleansLT1's Avatar
You might have to change the engine accessories around...
Old 07-04-2011, 10:46 PM
Sof86's Avatar
Unless your 100% sure its an LT4 and you are getting it for a good price why not just cam your LT1 and call it a day?
Old 07-06-2011, 01:02 PM
97Z28SS's Avatar
Here's how to tell for sure, pull the oilpan and look for 4 bolt mains, if yes then you're half way home, next oull the intake and look at the intake ports in the heads if they're tall and rectangular then you should be good to go. Also pull the valve covers and look fot LT4 cast into the heads.
Old 07-13-2011, 05:03 PM
my lt1 is cammed but its got problems i wanna stick a motor in it and sell it
Old 07-13-2011, 06:22 PM
defaultexistence's Avatar
You want to save the lt4 over an lt1 ... It's like saying.... Hey will an ls6 fit in my___, because I Wana keep my ls1 and get rid of the car.... Dumb dumb dumb ... Dumb dumb
Old 07-14-2011, 09:17 AM
Project382's Avatar
Agree!
Old 07-14-2011, 10:41 AM
93Z2871805's Avatar
Just look for the raised edge on the intake manifold where it meets the heads. GM put extra material there with the intent of opening the port on the manifold for the raised port on the head. As well as pulling the valve covers and looking for the casting numbers.
Old 07-16-2011, 05:35 PM
the_merv's Avatar
Also the LT4 has no EGR.
Old 07-17-2011, 09:50 AM
Village Troll
SS RRR's Avatar
Chowderhead here brings up a good point.
GM made an EGR block off plate for the LT4 which was pretty thick and rounded. That would be the first place to look. If there is a block off plate and it's flat and thin then most likely it's aftermarket and should lead to further investigation.
Quick Reply: will an lt4 work in a camaro
