Small Block & Big Block Chevy Specific - Anyone give me a little SBC help
View Full Version : Anyone give me a little SBC help
Camaro350Z28
07-03-2011, 09:12 PM
Purchased some vortec heads, 12558060 for my 77 truck with a 350. Can anyone give me a part number for intake manifold gaskets and a decent head gasket to use? thank u im having trouble figuring the right gaskets
CNC BLOCKS N/E
07-05-2011, 07:03 AM
A 1255 intake gasket will work or one right from GM and the 1003 head gaskets would be a good choice just foolow the instructions as you many need an extra hole drilled in each deck on some of the older blocks.
Camaro350Z28
07-05-2011, 12:21 PM
sweet thanks! i figured out the 1255.. then on head gasket i found 501sd... would that work? or should i just get the little more spendy 1003?
TheGreat4.8
07-14-2011, 12:47 PM
just make sure you seal them up good, i made the mistake of only putting sealer around the water jackets and ended up sucking oil on the bottom of the runners so another $34 on gaskets. I used gorilla glue on the new suckers never had another vacuum leak.
