hughes 2500 stall converter only preloads to 1300rpm, what gives?
Old 07-04-2011, 01:45 AM
93z28ltfun's Avatar
Default hughes 2500 stall converter only preloads to 1300rpm, what gives?
I just got a 2500 stall converter for my 93 z28, it was at summit on the discount rack for $100, and it only preloads to 1300rpm. my stock one went to 1100rpm before the tire broke loose. the rear brakes are good with brand new pads and rotors so im kind of stumped. I know it wouldnt preload to 2500 behind a near stock lt1 with a stock cam but 1300rpm doesnt make it worth it. any thoughts?
Old 07-04-2011, 02:09 AM
jimbob's Avatar
Thats transbrake or flash stall. NO ONE can give you accurate footbrake stall for obvious reasons.
Old 07-04-2011, 03:54 AM
01ssreda4's Avatar
It's configured a little off. It happens sometimes, especially with the cheaper converters.
Old 07-04-2011, 04:47 AM
BrianC98Z28's Avatar
this is what gives and is the problem
Old 07-04-2011, 05:50 AM
lt1-xjs's Avatar
You should have done more research, the Yank SS 3600 is by far the best all around LT1 converter.
Old 07-04-2011, 08:03 AM
Marc 85Z28's Avatar
Sounds like you got a cheap hacked up stock 12" converter. COMPLETE waste of money.
Old 07-04-2011, 09:46 AM
poltergeist 02's Avatar
sell it.
Old 07-04-2011, 10:34 AM
ULTIMATEORANGESS's Avatar
exactly.
Quick Reply: hughes 2500 stall converter only preloads to 1300rpm, what gives?
