Settings for LCA's for the drag strip?
Old 07-04-2011, 11:33 AM
98z28CamaroJG's Avatar
Default Settings for LCA's for the drag strip?
I just bought some Rear LCA's from UMI, the adjustable ones with the spherical rod ends, model number 2016. I want to install them this week for my upcoming trip to Cecil County Dragstrip. Any recommendations on how to adjust them to give me the best performance?
Old 07-04-2011, 11:41 AM
bigj2717's Avatar
The adjustment just moves the rear end forward and backwards. Just center the rear end in the middle of the wheel well.
Old 07-04-2011, 09:19 PM
SS SLP2's Avatar
adjustable Rear LCA's are use to center the wheels, but more important they are used to adjust the rear thrust line, get a complete 4 wheel alignment, I suggest set the thrust line close to "0" maybe a little + but no -, a good setting will help you leave the line stright
Johnny
Old 07-06-2011, 07:20 PM
Sounds good thanks guys I'll be getting the alignment asap
Old 07-07-2011, 09:29 AM
bpittman's Avatar
Can someone explain some more what the rear thrust line is? Is that axle tracking straight when compared to the front tires?
Old 07-13-2011, 02:18 AM
Actually i would also like a little more information about rear thrust line too. And also, what would the factory specs for Rear Thrust Line be for my car? Just so im sure my free alignment at Firestone actually works out haha
Quick Reply: Settings for LCA's for the drag strip?
