No start brand new red top optima battery LT1 bad luck finally caught up with me
Old 07-04-2011, 07:51 PM
killagt's Avatar
Unhappy No start brand new red top optima battery LT1 bad luck finally caught up with me
2 day ago, I crank car, nothing happent, then I wiggy the battery and it start. yesterday i put in brand new red top optima battery, car crank right up no problem, today I stop by gas station, and try crank it, nothing happent, I heard a very low click noice under my passenger seat, I have light and everything, turn key nothing happent. here what I already try
I hit the **** out off the starter
wiggy the battery left and right
im so embrassing, this nice black dude help me push the car to the parking spot. man im feel so bad atm
Old 07-04-2011, 08:04 PM
bigj2717's Avatar
Is the security light coming on?
Old 07-04-2011, 08:26 PM
killagt's Avatar
all light in dash on, light look normal, bright.
Old 07-04-2011, 08:36 PM
transbird95's Avatar
I thought you sold your LT1?
Old 07-04-2011, 08:39 PM
killagt's Avatar
I kept the 1LE one, im thinking selling it
Old 07-04-2011, 08:48 PM
bigj2717's Avatar
Well if the security light is on it might just be the VATS unless you have bypassed it. Everything else will work and it wont even try to crank
Old 07-04-2011, 08:50 PM
idformula's Avatar
Clean battery cables?
Old 07-04-2011, 09:00 PM
gregrob's Avatar
Make sure ground is tight, opposite end of the battery.
Old 07-04-2011, 09:07 PM
TAEnvy's Avatar
If you have a bad alternator it could have killed the battery. Need to get the car runnig to check it though. Get jumped off, if it starts then youve got a weak/dead battery, check your volt guage, if its low you need an alternator.
but check your cables first
Old 07-04-2011, 10:25 PM
killagt's Avatar
I just put this in yesterday
7 month ago, when I crank my car, it make a grind noise, my friend say " HEY U NEED CHANGE THAT STARTER OUT " my car make grind noise every time I crank it, I though it those pulley or something.
Tomorrow imma take that red top off and exchange for the starter one from advance auto part. 149 dollar.
Can u guy show me how to take off the starter ?
Old 07-04-2011, 10:47 PM
Lawhead's Avatar
its 2 bolts.........
Old 07-04-2011, 10:54 PM
killagt's Avatar
Hi do u know what size the bolt is . The car is 20 min away from my house, I have to left it there over night . reason I ask about the bolt size so I can bring the right tool tomorrow.
Old 07-04-2011, 11:17 PM
95FbFormula's Avatar
13 mill hold down bolt 8 mill on the battery bolts
Old 07-04-2011, 11:19 PM
make sure u bring an extension for the hold down bolt
Old 07-04-2011, 11:27 PM
killagt's Avatar
guys, im sorry for keep asking question, my car is not ok, so im kinda not myself atm.
I did a search and some say LT4 starter is better then LT1 and some how cheaper. some say using starter of a 96 vet LT4
http://shop.advanceautoparts.com/web...539216788____#
is this the right one, and that 96 lt4 vet starter will bolt right in my 97 camaro z28 6 speed ? thanks
Old 07-04-2011, 11:34 PM
Jersey Mike's Avatar
Try the obvious things first.
Disconnect the battery and connect the terminals on the battery & the terminals on the cables.
Reattach the battery cables and make sure they're TIGHT and making a GOOD connection.
Try starting the car. If it doesn't start, try it with a different battery, or by getting a jump start from another car.
If still nothing, I would tow it home, rather than doing the repairs in the gas station parking spot. Get an OHM meter and check down the wires to see if there is power throughout.
Check all of this stuff before you spend any money playing the guessing game.
Old 07-04-2011, 11:57 PM
That's MISTER MODERATOR
Paul Bell's Avatar
It's not very smart to get to the car with only the one or two tools you'll need. I suggest you take a good set of tools, drop light, moving blanket or cardboard to lay on, a good jack....
I would also suggest you not try this alone.
Old 07-05-2011, 01:11 AM
idformula's Avatar
How about roll starting it? If it is infact the starter, it will still start.
Old 07-05-2011, 01:20 AM
killagt's Avatar
When I try start, all I heard is very low sound of click under my passenger side. When my friend try crank while im hammer the starter, im just click 1 click each time he turn the key all the way. Hopefuly it just a starter.
Old 07-05-2011, 01:47 AM
idformula's Avatar
By roll starting bud I mean have the key on the on position, the car rolling about 20-25mph and poping the clutch in 1st or 2nd. If it starts then its probably your starter, if not then you have other problems.
Quick Reply: No start brand new red top optima battery LT1 bad luck finally caught up with me
