Removed my burned Spec clutch; which stage it is? pic inside
Old 07-05-2011, 01:21 PM
Johnnystock's Avatar
Question Removed my burned Spec clutch; which stage it is? pic inside
Like the title says, anyone knows what model it is?
The flywheel is heavy as hell, around 50lbs LOL its an old model, 6 years old at least..it started to slip recently on the juice. There is no part number on anything.Is the flywheel still good too, after resurfacing?
Attached Thumbnails Removed my burned Spec clutch; which stage it is? pic inside-clutch-spec-1.jpg   Removed my burned Spec clutch; which stage it is? pic inside-clutch-spec-2.jpg   Removed my burned Spec clutch; which stage it is? pic inside-clutch-spec-3.jpg
Old 07-05-2011, 04:55 PM
thesource's Avatar
Stage 3.
Old 07-05-2011, 05:11 PM
LS1-450's Avatar
Yup, +1 on the stage 3. Regarding the flywheel, generally, they can be cleaned up (re-surfaced) once. As long as, it's not much under the manufacturer's minimum thickness, it's good. Just, don't ask me the minimum thickness, 'cuz I don't remember. FYI, I've gone .030" under minimum thickness without any flywheel flex issues on 500+ BHP. If you do this make sure to have an adjustable clutch master cylinder or use a flywheel spacer to make up the difference (point being, don't do something like this (under min. specification) blindly).
On spray, you'll want to go w/ a full clutch disk like a 3+; more surface area. Spec can tell you the best recommendation based on your BHP while using spray.
Old 07-05-2011, 08:36 PM
Originally Posted by thesource
Stage 3.
ok good
thanks buddy for the info;I was going to check for shimming anyway I was thinking about a LS7 clutch lately for the price and cause my car only sees roll racing and very occasional spray. Plus, I would have a more streetable clutch..but I'm leaning toward a Spec 3 again or a Monster.
I called Spec and they suggest me a Spec 3+ but its outta my price range, unless if I reuse my flywheel..
Old 07-06-2011, 05:19 PM
rob69zombie's Avatar
I used a Spec 3 for a couple of years and I'm going to an ls7. My friends run ls7's and I LOVE the feel of them. It'll hold 525rwhp safely with limited track use; why not have a comfortable pedal too? lol
Old 07-06-2011, 05:26 PM
SNLPerformance's Avatar
Give us a call and we'll go over some Monster Clutch options with you.
Old 07-08-2011, 04:45 PM
Sprayed1998's Avatar
Ls7 will not hold 500+rwhp or spray well.
Old 07-08-2011, 05:42 PM
Quick Reply: Removed my burned Spec clutch; which stage it is? pic inside
