Crankshaft Balancing Cost
Someone said recently that that you're not really saving much money by skipping a stroker crank because when just swapping to forged rods and pistons, so much metal has to be added to the crank it adds so much to the cost of re-balancing the stock crank that you may as well have gotten a stroker crank. But even a stroker crank would have to be balanced to the chosen rods and pistons so.....
Is the cost variable and if so what is the range? I've been working under the assumption that I could throw in forged pistons and rods for decently cheap and call it good. Rods - $500, pistons - $600, so bearings, head studs, gaskets and balancing would be all I'd need. If that stuff is going to add up to $$$ I'd rather get an HKE iron 402 short block and sell my stock LS2 shortblock.
Just spit balling.
Just spit balling.
I paid $350 for the balance work done to my rotating assembly (forged crank rods and pistons) in addition to a LOT of other machine work. I felt it was a fair price. I'm sure you could find a better price somewhere, and I'm sure others would charge more...but I like knowing that someone with a great reputation did the work.
The following users liked this post:
swathdiver (05-19-2022)
Balancing rotating assembles is misunderstood by a lot of enthusiasts. Paying extra for peace of mind is fine if you have the funds to do that. This is an area in engine building where not understanding what is being done costs you extra. Lots of bs on balancing because who can check it out when you get done? You are all relying on someones opinion.
of course they put bob-weight on that is equal to your piston rods rings and bearings . mine was $125.00 with the before and after
Never heard of balancing just the crank, what purpose would that serve?
I sorta agree. Callies did mine (it's their crank and rods with JE pistons) when I gave them all the numbers on the other parts...a very very small amount of weight was removed from my crank by my builder to make both he and I comfortable with it...like I said, it was probably "good enough"...
Thanks guys. Sounds like it's not a big cost to get the crank balanced to the new pistons/rods. There is a little to be saved by buying a rotating assembly but you have to spend the $$$ on the crank.
-Adam @ Callies
Thank You very much, w/ balancing equipment costing 30K shops need to charge accordingly for there services
Hebert's Diesel Engine machine shop
Thibodaux la
99 Black Bird T/A (05-20-2022)
I just paid $150 to have my crank balanced. That was a brand new factory LSA crank from the dealer, Callies Compstar H beam rods, and Summit Pro LS (Wiesco) forged blower pistons. Like you said, $600 rods and $600 pistons. The pistons and rods are heavy, I am using thick tool steel pins too, but surprisingly, the crank did not need weight (mallory) added to it. Some drilling into the counterweight edges, and it was all set. LS is neutral balance damper and flywheel, so they stayed home.
If you are not doing a high level of forced induction, you can probably skip the head studs and save more $?
