what fuel injectors lt1 355 build
Old 07-05-2011, 05:18 PM
redtransam95's Avatar
Default what fuel injectors lt1 355 build
lt1 355
6in rods
mahle pistons
stock crank
le2 cam and cam
looking for 400-430 rwhp
what size injectors should i get was thinking #36 whats a good brand thats budget friendly and part number? I dont know squat about injectors someone educate me please
Old 07-05-2011, 07:18 PM
grunt1152's Avatar
Im interested as well. Maybe try posting in the LT1 section if not many replies from here.
Old 07-05-2011, 08:58 PM
FICINJECTORS's Avatar
Originally Posted by redtransam95
lt1 355
6in rods
mahle pistons
stock crank
le2 cam and cam
you should run a bosch 32lb here's sum links.these will also be a direct fit for the lt1 rails.feel free to give us a shout for tech info.770 888 1662
http://www.corvetteinjectors.com/sho...?productid=180
http://www.corvetteinjectors.com/sho...?productid=197
Old 07-05-2011, 09:10 PM
well i was going to run the old red top #30 svo injectors rated at #36 with lt1 psi but cannt seem to find them anywhere for sale anyone know the non ford part number for these or would they not be the same injectors? looking for quaility and value here
Old 07-05-2011, 09:18 PM
although i do like those and will keep them in mind
Old 07-05-2011, 09:20 PM
your lt1 runs a fuel pressure of 43.5psi the svo red top part# 0280 150 945 is a 30lb at 39psi.it will flow 32lb at 43.5psi
we stock them. but i would recommend the newer style they will fit your rail much better plus they are 100% stainless internals.
Old 07-05-2011, 09:45 PM
what all will a tuner need to know to tune these in?
Old 07-05-2011, 09:50 PM
you would say that you are running a bosch 32lb injector, I have the offsets etc to go with them if he needs them
Old 07-07-2011, 04:32 PM
deatschwerks's Avatar
We've got a 35lb injector that would work great for what you are wanting to do.
Drop-in fitment and flow matched to within 2% at both low and high pulse-widths.
http://www.deatschwerks.com/products...z28-ss-1998-02
Quick Reply: what fuel injectors lt1 355 build
