E3 plugs
Old 07-05-2011, 06:45 PM
faceman69's Avatar
Default E3 plugs
How do i get around the A/C condenser to replace the plugs without breaking out the saws all? i removed the R/F tire to see if there was a cutout for access, but didn't see anything, any help would be great, and feel free to give me the "your a dumb ***, speech" thanks
Old 07-05-2011, 06:53 PM
2001NBMZ28's Avatar
Think you mean something other than the AC condenser - maybe the EGR (depending on your year). Or are you talking about #8?
Old 07-05-2011, 06:56 PM
SuperSlow02's Avatar
take the coil packs off and it just take getting use to
Old 07-06-2011, 12:25 AM
garygnu's Avatar
#8 from down under.look at ls1howto.com for some pics.
Old 07-06-2011, 03:40 AM
kmracer's Avatar
please tell me you didnt put "E3" plugs in there...
Old 07-06-2011, 04:58 AM
myk
myk's Avatar
Hang in there, 'OP. You can grab all of the plugs from the top as long as you move the coil packs out of the way...
Old 07-11-2011, 02:14 PM
faceman69's Avatar
thanks man,
Old 07-11-2011, 02:23 PM
sjsingle1's Avatar
E3 plugs got me a extra 40 horses........i got them a vato zone !!!
Old 07-11-2011, 06:30 PM
408lq4's Avatar
not a e3 fan at all
Old 07-11-2011, 08:58 PM
Jahmalljames's Avatar
Whats wrong wit e3's
Old 07-11-2011, 10:09 PM
Element's Avatar
They're a gimmick, just like the Bosch +4s.
Old 07-11-2011, 10:15 PM
TheWarden's Avatar
OP..i just did a tuneup on my 98 trans am 2 days ago..u can probably still see the thread i started asking the same question..fron underneath it was impossible because the exhaust manifolds are in the way..so wat i did was took out all of the A/C lines..every silver A/C line was taken out..then i took off the number 7 coil pack..this gave me 100% more room to get to the last 2 plugs..the easiest way was to take the spark plug socket and put it on the plug by hand..then take the wrench with a universal head (u probably need an extension) and put that on the socket..i did this for every plug and it took about and hour to finish
Old 07-11-2011, 10:34 PM
StuntmanMike's Avatar
^^^ I changed my #8 plug and wire from underneath, it was easier. I spent more time messing with the stupid coil rail bolts than I did actually chaging the plugs. I ended up just leaving the coils where they were, I found it unecessary to move them.
Old 07-12-2011, 03:34 AM
myk
myk's Avatar
Update 'OP! Also, did you have to move the exhaust out of the way to get to #8, StuntMike?
Old 07-12-2011, 08:20 AM
Element's Avatar
So you basically did an AC delete just to change plug wires?
And here I'm not having that hard of a time with the coil packs on and gorilla hands.
Old 07-12-2011, 03:28 PM
TheWarden's Avatar
ya..my dad had been if the refrigeration business his whole life..so it was nothing to me to take it all out then put it back in and recharge the A/C
TheWarden's Avatar
and it was to change all the plugs to not just plug wires
