compression test lq4
Old 07-06-2011, 12:20 AM
IamSam's Avatar
Default compression test lq4
I took a compression reading of 4 random cylinders on my LQ4. Engine warm with throttle blade wide open, I got exactly 165PSI on the 4 cylinders I checked. I checked 1,3,2, and 4. I found it strange that they were all the exact same. Engine has a little over 250K miles on it.
Old 07-06-2011, 01:08 AM
Restricted User
z99ls1's Avatar
Thats pretty damn good compression readings for those miles. Sure your gauge doesn't go by 5's or something and they wur a little off, but you just didn't notice?
Old 07-06-2011, 01:53 AM
IamSam's Avatar
Sorry, i meant to ask if the readings are decent for an LQ4, i couldnt find the specs for the lq4's. Anyway its the harbor freight gauge, it divided the lines and they each should be 5 psi. Either way they couldnt be more than a couple PSI apart if any. Thanks for the quick response!
Old 07-06-2011, 02:39 AM
Restricted User
z99ls1's Avatar
Yea im sure that is good. Thats right in the range for a bigger performance motor
Quick Reply: compression test lq4
