MS4 on stock pistons?
Old 07-07-2011, 02:46 PM
mattzoom's Avatar
Default MS4 on stock pistons?
Can you run a MS4 cam on stock pistons and not have PTV issues? without having to flycut them?
Old 07-07-2011, 02:57 PM
Marc 85Z28's Avatar
If the heads and gaskets are stock yes. If you have thinner head gaskets, or larger valves, or milled heads, etc you will need to clearance the pistons.
Old 07-07-2011, 02:59 PM
MYSTIC-1SC's Avatar
Should clear no problem with stock cylinder heads and gaskets.
Old 07-07-2011, 03:00 PM
mattzoom's Avatar
Going to be running these heads- http://www.texas-speed.com/p-1177-pr...ted-heads.aspx
Old 07-07-2011, 03:04 PM
mattzoom's Avatar
I believe they are 64cc
Old 07-07-2011, 03:06 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Stage 3 heads really aren't ideal for an LS1 short-block to start. The valves are too big and are shrouded on the relatively small bore.
The next issue, if you decided to run them shrouded like that, would piston to valve clearance. You will need to flycut the pistons FOR SURE with that camshaft and those heads!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-07-2011, 03:11 PM
mattzoom's Avatar
Thanks thats what I thought, what about the ms3? still tossing around ideas on a cam, the car its going in is a 69 camaro track/street car, more track then street
4000 stall
vic jr intake
full bolt ons
th400
4.10 gears
small 100 shot
hopin for low 11s high 10s maybe
and im getting a good deal on those heads so I am going to see how it does.
Old 07-07-2011, 03:15 PM
4000 stall
vic jr intake
full bolt ons
th400
4.10 gears
small 100 shot
Still shrouding the valves....MS3 still needs flycut with them as well. Anything over about a 2.04" intake valves is too much for your LS1 bore.
__________________
Old 07-07-2011, 03:17 PM
mattzoom's Avatar
well looks like Im going with the MS4 if I have to flycut them either way, thanks for the help Matt
Old 07-07-2011, 03:19 PM
Not sure if I'm just not conveying this well enough or what, but those Stage 3 heads SHOULD NOT be used on a standard LS1 bore. The valves are shrouded (too close to sleeves) on the small bore.
__________________
Old 07-07-2011, 03:21 PM
mattzoom's Avatar
I got it, what heads do you reccomend?
Old 07-07-2011, 03:34 PM
For a real tight budget, stock LS6 heads would be a good upgrade over the LS1's you have. Or, for a little more money the Stage 2.5 5.3's and MS3 would be a blast and knock down some great ET's (of course with the proper bolt-ons and suspension upgrades!) For a wider budget, the aftermarket castings, be it PRC or TFS, would be the best performance!
__________________
Old 07-07-2011, 03:42 PM
mattzoom's Avatar
Alright thanks
Old 07-08-2011, 01:06 PM
redracer1's Avatar
Matt, Datzneat has the MS3 stage 2.5 5.3's w/FAST on his build he put 470+ rwh. You add that 150 shot = money
And sometimes a good deal isn't a good deal
Old 07-08-2011, 01:37 PM
sabersaw30's Avatar
The prc 5.3 heads are tough to beat on the street.You can keep all the down low torque to kill them big headed cars.
Old 07-08-2011, 03:39 PM
PREDATOR-Z's Avatar
That has been proven to be incorrect. The trick is not the size of the runner, but its ability to move air and maintain velocity.
Old 07-08-2011, 07:48 PM
mdeanlittle's Avatar
matt i have been calling texas speed all week trying to figure out will the stage 2.5 heads work with the ms3 or tsunami cam without cutting the pistons please let me know
Old 07-08-2011, 07:49 PM
on a stock 346 ls1
Old 07-08-2011, 09:29 PM
sabersaw30's Avatar
Just my opinion.You are probably right but i like the small runners on a fast street car.I don't want to highjack the mans post.
Old 07-11-2011, 09:29 AM
mattzoom's Avatar
on a stock 346 ls1
bump for this guy
I am also lookin at these heads- http://s322636171.e-shop.info/shop/a...e.html?pse=apq
Quick Reply: MS4 on stock pistons?
