lovinmyz
07-08-2011, 12:48 PM
87 rx7 ls1/t56 for sale
price: price drop 8000
contact: 2674675272
Engine:
01 ls1 motor milage: 34k when i bought it
6 speed t56 trans
ls6 intake manifold
bbk modified long tube headers
3" y pipe to 3" exhaust piping to the back
no cats or mufflers
mgw shifter
walboro 255 fuel pump
improved racing oil pan baffle
turbo II rear diff
Exterior:
enkei rpf1s 18x10.5
enkei rpf1s 17x9.5
s5 rear tail lights
Suspension:
bc coilovers
MMR Spherical Rear Control Arm Bearings
MMR Front Control Arm Bushings
MMR DTSS Eliminators
MMR Rear Subframe Mounts
MMR Rear Differential Mounts
AWR Rear Camber Adjusters
AWR Rear Center Brace
AWR Rear Toe Link Kit
Interior:
OMP Bucket seat (seat rails bolted to the floor for clearance)
Nardi steering wheel
momo hub
nrg quick release
nrg harness bar
2 crow harnesses
seat and harness are up to date
autometer tach, speedometer, water temp, oil pressure
s5 center cluster
Little Problems:
fan is always on
tach and speedo cut on and off on bumps
no mufflers
little dents here and there
no ac no heat
no back seats
text me or call me, i will most likely not pick up being that i will not know your number, leave a message. i put up pretty big pics of everything so every one can have a pretty good idea about the car before coming out to look at it. the car will not get delivered any where, come and get it with cash in your hand. i dont want to trade unless its a car with a 1jz or 2jz, i would really love an is300, must be stick, or an sr car that puts down serious power. dont offer me anything less than 8500. the car has its problems, if you come see it, expect to see a car that is still a work in progress. previous owner claims to say the swap has 34k miles on it, i did not drive it much during winter, its been a year since ive had the car this month. the car was originally swapped in florida then was bought by some one in jersey who didnt drive it much which is the person i bought it from. it runs with no problems at all
http://www.rx7club.com/showthread.php?t=903425 (this is the link from the previous owner)
http://i812.photobucket.com/albums/zz46/lovinmyz/7b023def.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/8138d852.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/83c25c65.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/995b9317.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/321b28ba.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/7b2690e8.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/35a7e50f.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/62960d58.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/b190c742.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/5f3c41b4.jpg
http://i812.photobucket.com/albums/zz46/lovinmyz/a2e74a9a.jpg
contact: 2674675272
Engine:
6 speed t56 trans
ls6 intake manifold
no cats or mufflers
mgw shifter
turbo II rear diff
Exterior:
enkei rpf1s 18x10.5
enkei rpf1s 17x9.5
s5 rear tail lights
Suspension:
bc coilovers
Interior:
momo hub
nrg quick release
nrg harness bar
2 crow harnesses
s5 center cluster
Little Problems:
fan is always on
no mufflers
no ac no heat
no back seats
