2002 trans am
2002 trans am
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $20000
Mileage: 66000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
3k on motor, tranny and rear end.
Motor
346cid stock rotating.
arp man studs,arp rod bolts, coated main and rod bearings. Total seal rings.
LPE ls6 heads dual valve springs,scorpion rockers,Texas speed pushrods,stock ls6 lifters, Texas speed ms4 cam, fast 90 with nick Williams 90 tb both ported by afr. Ford 38lbs injectors,k&n fipk2, partial tune done. Needs more done mostly for shifts, then motor.
Transmission
Yank 4000ss, transmission was built by a local tranny man with all the goodies.
Drivetrain
Moser 12 bolt, 3.73, tru track,32 spline axles? Have to check when I get home. Works with tc and abs. Pst driveshaft
Suspension
Bmr subframe connectors, spohn lca,phb, torque arm,relocation lca brackets new have not been put on spohn k member with solid motor mounts both new not installed.
Might of forgot some stuff... hooker school pt headers off road y with sop lm1 exhaust, oil and fanny temp guage. Hopefully pics pop up. Uploaded from phone. If they don't tex me (260-375-6118) do not call because I will be at work and I do not carry my phone on me. If the pics don't show I will send them to you.
Might trade plus cash for a 08 newer black on black cobalt ss turbocharged. Thanks for looking
Keith
