Can you use OIL PRESSURE 5v for Wide Band o2 in HPTuners?
Just like the title says, I know people use EGR and AC pressure, I am using a 04 Express Van PCM, no EGR and no A/C pressure (just a simple high/low pressure switch setup).
I am not using the oil pressure sensor so I figure I could use it to get my wideband data.
Any idea?
Any idea?
are you sure there isn't a pin on the pcm for EGR? I have an 2001 Trans Am (no EGR) but the pin is still there for EGR on the computer, I tapped right into it, to log AFR on HPTuners. If there is no pin for EGR, I would be willing to bet there is a PIN for A/C is on the computer, you just have to tap into it directly at the PCM.
