02 sensor question?
02 sensor question?
Hey guys,
I am running a ls3 setup on my camaro.
will I need just 2 o2 sensor? Im not running a cat convertor on the car.
will a stock o2 sensor work? or do I have to buy a wide band o2 sensor?
what sensor do you guys recomend?
denso, bosch, etc....
thank you.
thank you.
With longtubes and no cats on a LS1 car you just run the up stream 02s and tune out the codes for the down streams. Is it a 5th gen car or a LS3 in a 4th? I would run GM or Bosch brand.
