Solid motor mount & Poly A4 trans mount?
Old 07-09-2011, 12:49 PM
Lazzarus's Avatar
Default Solid motor mount & Poly A4 trans mount?
Is it safe to run a solid motor mount & a poly trans mount? I don't care about vibration, I just want to know if it's going to cause extra wear and tear or be dangerous in any way. This would be with an A4 setup. Thanks.
Old 07-09-2011, 01:10 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running solid motor mounts and a prothane trans mount(it's a TH350) in my Trans Am, haven't had an issue yet
Old 07-09-2011, 02:31 PM
99Bluz28's Avatar
Shouldn't be a problem.
Old 07-11-2011, 12:42 AM
2000PewterT/A's Avatar
Like everyone else said, you should have no problems.
Old 07-11-2011, 02:53 PM
wicked383lt1's Avatar
Now the question is where did you find them?
Old 07-11-2011, 06:29 PM
408lq4's Avatar
will not be a prob
Quick Reply: Solid motor mount & Poly A4 trans mount?
