C5 fuel sender...Can this be repaired?
Old 07-09-2011, 05:12 PM
DopeFedZ's Avatar
Default C5 fuel sender...Can this be repaired?
I was moving the sender to the new RSI fuel hat and l ended up pulling the wire and solder completely off the board. Can it be resoldered or reattached or do I need to order another sender?
Old 07-09-2011, 09:58 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I've never had any luck soldering one...
Judging from the pits on the sensor, it was bad anyway.
Old 07-10-2011, 12:22 PM
Destroyer of Exotics
FlashWS6's Avatar
just get a new one, i don't wanna have to rescue you 2 again in this summer heat LOL
Old 07-11-2011, 05:14 AM
All-In's Avatar
Location: Just because the voices aren't real, doesn't mean they're not right!
I agree. I think those leads are silver-soldered anyway and that involves even more heat that regular solder.
Driver's side GM part # for a C5 is: 10333749 or the AC Delco # is SK1318. It is available from several sources, including some forum sponsoring dealers or RockAuto, etc, so there's no need to pay full list price from a regular dealer.
HTH
Old 07-11-2011, 03:28 PM
LS1TECH Sponsor
It not the solder, but the fact that you are trying to solder to a circuit board.
The large area meant to attach the wire to is pulled off the board.
The small remaining trace is not strong enough to securely hold the wire in place.
Old 07-15-2011, 07:03 PM
Twotonefreak's Avatar
Gonna have to get another one. Been there done that.
Old 07-20-2011, 03:38 PM
DopeFedZ's Avatar
Thanks guys another one has been ordered.
