MAF diameter?
Old 07-10-2011, 08:16 PM
VandykeT/A's Avatar
Default MAF diameter?
Can anyone tell me if the overall diameter of a 85mm maf is the same as a stock one? Such as where the bellow would go around it. I know 85 is bigger than 75 but Im thinking maybe its just the inside thats bigger thanks.
Old 07-11-2011, 12:13 AM
2000PewterT/A's Avatar
Not 100% sure, but I believe the 85mm is bigger
Old 07-30-2011, 11:37 PM
fastsspr's Avatar
That is a good question ???
Old 07-31-2011, 01:35 AM
R6cowboy's Avatar
I just measured both of them with the micrometer. The outside diameter of the 75mm MAF (from a 2000 Vette) measured 3 5/8" and the 85mm MAF (from 2005 Vette) measured 3 7/8". These were measured from the front of the MAF's. Hope this helps.
Old 07-31-2011, 04:16 PM
joecar's Avatar
The bellows goes on the rear of the MAF, can you measure the rear diameter...?
Can you remeasure the front in millimeters, please...?
Old 07-31-2011, 07:01 PM
trans_am7935's Avatar
i had a smooth bellow on my stock 75mm one, and then upgraded to a 85mm GM one, bellow slipped on just fine
Quick Reply: MAF diameter?
