85mm MAF ???
Old 07-10-2011, 09:58 PM
silverstreak98maro's Avatar
Default 85mm MAF ???
IM RUNNING STOCK SMOOTHED OUT MAF AND SLP LID WITH PORTED BO WHITE 78mm TB. WHAT GAINS WOULD BE SEEN WITH GOIN TO 85mm MAF AND LID??? IF ANY
Old 07-11-2011, 12:14 AM
2000PewterT/A's Avatar
Not much, maybe a few hp at best.
Old 07-11-2011, 03:43 AM
*02WS6TURK*'s Avatar
It's hard to tell what kind of gains would be had being we don't know your current set up?? Bolt on only? Cam only? H/C?
I made the switch to a GM 85mm MAF & Fast Toys 98mm lid after my EPS cam swap and only picked up a couple HP at the rear.
Old 07-11-2011, 06:18 AM
Default pcv
my setup is stock bottomend tsp stage 2.5 243 heads, 236/242 6xx/6xx 112+4 cam, ported 78mm tb, slp lid 25%ud lt's lm1 exhaust, ls6 intake, just wondering if the 85mm maf is better for this setup
Old 07-11-2011, 10:27 AM
Mike Morris's Avatar
Yes it will. But keep in mind some tuners claim the bigger 85MM pegs out sooner if you decide to go crazy with power beyond 500 at the wheels
Old 07-11-2011, 05:24 PM
HoLLo's Avatar
You will need a tune with it, so don't worry about an 85mm MAF until you get a bunch of mods together to make the tune worth it... I've had tuners tell me they won't tune it with the 85mm, only a stock one.
Old 07-12-2011, 10:45 AM
I would look into upgrading your LS6 intake to maybe a Fast 90/92. The gains would be pretty good since you have heads & cam.
Old 07-12-2011, 12:19 PM
brianw401's Avatar
I agree with all of you. Wait until the meter becomes the last restriction in the air tract before replacing it. Your money will be better spent elsewhere. I'm putting down over 480hp @ the tires & still have a stock unit.
Old 07-12-2011, 02:39 PM
Dirty Vegas's Avatar
Really? Cause I know a few tuners that would throw a ported stock MAF at your head. Just search on this site for ported MAF's and grenaded transmissions. Ported MAF's and after market MAF housings are always a bad idea.
Old 07-13-2011, 08:58 AM
NHRATA01's Avatar
Been running an 85MM descreened GM LS6 MAF since '02. The important thing with a MAF is not to bolt it on and go, but to get a tune right after install. I would stick with a GM MAF if you want to go larger as you can be confident it has been properly calibrated to factory specifications. I would be less confident in the aftermarket companies (like Granatelli) and agree that messing around with ends and porting the stock MAF is asking for problems. There are some gains to be had with a larger MAF as it is less of a flow restriction, however since it's role in metering air is critical you need to do it the right way.
Old 07-30-2011, 11:30 PM
fastsspr's Avatar
WoW...But that 480hp is with the stock unit ported or unmodified???
Old 07-31-2011, 10:05 AM
mike c.'s Avatar
On my old ls1 head and cam set up. I gained 9hp going from a stock ported mass to a gm 85mm truck massair.
Old 07-31-2011, 10:19 AM
disc0monkey's Avatar
you can get a 85mm MAF for cheap, if your going to get a tune anyway youll pick up at least 5rwhp. for what i paid for mine its a great hp/$
Quick Reply: 85mm MAF ???
