92 Mustang LX 8.50 roller with turbo set-up for LS motor
Year: 1992
Make: Ford
Model: Mustang
Price: $12000
Mileage: 9999
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
92 Mustang LX - calypso green
CHASSIS
-minitubbed
-Wolfe CM 10 point w/ extra bars to strut towers and frame
-cage painted hammertone gray
-Subframe connectors
-Lower Battleboxes with bars to cage
-upper torque boxes welded
-PA k-member
-PA 1" shorter a-arms
-Strange adj. front struts with Strange 175 lb. springs
-QA1 caster/camber plates
-Wolfe DA uppers with spherical bearings
-PA Double adj. offset lowers
-AFCO Double adj. Big Gun coilovers
-UPR anti-roll bar
-8.8 narrowed 3" each side, welded and braced with 9" ends
-FMS 3.27 gear
-Moser 35 spline axles with 5/8 studs and Moser spool
-T/A girdle
-Racecraft LCA brackets moved in 2"
-Billet Specialty Street Lites, 15x12 rear and 15x3.5 front
-Moroso DS2 fronts and 28x10.5 Hoosier stiff sides
-Strange front and rear brakes
-Pinto rack with Racecraft bumpsteer kit
-Stroud parachute with removable mount
-Racecraft strutless wing
-Kirkey prostreet seats
-B&M supercooler in aluminum tank in hatch for ice
-B&M Prostick with magnum grip
FUEL SYSTEM
-15 gallon cell with sending unit
-Magnafuel EFI 750 pump
-Aeromotive pre and post filters
TURBO
-custon truck manifold kit
-Bullseye Power S480 with race cover
-60mm wastegate
-50mm Tial BOV
-4" thick A2A intercooler
everything was bought new and car was built less than a year ago.
located in hammond, indiana
$13.5k FIRM for roller with fuel system and complete turbo set-up for LS motor
$12kFIRM for roller without turbo set-up
