How to set up ABS and E Brake to 9"
Banned Scammer
This is what im considering at a local buy-----
Moser 9" p/c black but has had lca relos and BMR arb brackets welded on after the rear was completed so they aren't coated at all, just cosmetics obviously. Rear is STOCK WIDTH, TRU-TRAC DIF, 4.11's with about 2000 miles on them and is Quiet! Nodular center, 31 spline and will come with backing plates but is not set up for abs or parking brake. All you will need is your T'bolts. Also has 1/2" studs.
How much/what would i have to do to set it up for ABS and E brake?
LS1Tech Sponsor
Do you need it set up for just ABS, or do you also have traction control? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Premium Sponsor
if the car is just ABS and not equipped w/ traction control we have a retrofit kit available to make the abs kit work w/o major mods to the rearend or center section. We also have the necessary brackets and tabs available to hook up your e-brake cables and brake hoses. call us if you are needing these items.
LS1Tech Sponsor
For traction control you need to have your axles machined to install the reluctor rings on them. You can send your axles to Moser in Portland to have them machined. 260 726-6689 is their ph#. Bob
__________________
If you want to keep the 4-channel ABS/TC, it will be some $$$. It will involve R&R both axles, getting and pressing on reluctor rings and new brake backing plates (unless the non-TC ones can be drilled-not sure about this). Definitley refer to the sponsers posting to this thread, Brute Speed & Midwest ... they do this every day!
I don't know how important the ABS/TC system is to you or if your WS6 is a DD, but since I am running a spool, a reluctor ring for my 3-channel (ABS only-single ring mounts on the carrier) SS was not possible, I am running with my "ABS INOP" light on and no ABS.
Unfortunately for you, you cannot do without TC and keep the ABS on a 4-channel car unless you do it electronically somehow with the switch. The ABS reads from the same place as the TC (reluctor ring on each axle at the brake backing plate) and controls both ABS and TC with a seperate brake line from the module to each rear brake.
LS1Tech Sponsor
http://shop.brutespeed.com/Brute-Spe...nformation.htm
The above link shows the locations of both ABS and ABS/TCS. Bob
__________________
Banned Scammer
So looks like i will probably be calling both you and bob to get some prices.
4-channel 9" with approx 4.11s
This will see a 3.5hr trip at 75-80mph about 4 times a month so we may go a little Lower on the gears ....
LS1Tech Sponsor
The Moser nine inch with a Trac-Loc is what I would go with for your car. The 4 channel ABS/TCS is an option. These rears ship out just two days after the order is received. 3.75 gears may be the way to go since you see some long trips with your car. Let me know if you have any questions. Bob
__________________
Banned Scammer
i am somewhat new. but this is what a member told me to go with
housing backbrace (may be overkill)
additional Meziere rear side filler cap assy
4 channel abs axle mod
billet clutch type posi(rebuildable)
black powdercoating on the rear and red on componenets (for looks obviously but i like it)
PST 3.5" aluminum driveshaft(M6)
completely assembled rearend ready to bolt-in
4.11 Yukon gear
(This Guy Had a MWC Fab9)
Also i was told the full length torque arm and polybushing mounts would help keep the ride smooth.
4.11 Yukon gear
4.11 Yukon gear
4.11 Yukon gear
I will send you a PM with all the details.
LS1Tech Sponsor
4.11 Yukon gear
4.11 Yukon gear
__________________
Banned Scammer
well both are reputible companies. no lie there so the only thing that will separate is pricing. and there is a $400 difference (i wont say due to thread rules)
LS1Tech Sponsor
Yes, both build a good rear. The Moser fabricated rear is more money but the customer gets it several months sooner. Either one though gets you a good rear. Bob
__________________
