Normal Injector Duty Cyle %s
Just wondering whats the best injector duty cycle to know that your injectors are not being maxed out of not keeping up? Just did a full tune on my new setup and seems like something is not keeping up as my cam is supposed to pull to 6100 which is does but then it dies right out like it hits the limiter and pulls back. Im thinking my injectors are maxed out then it gets to that point. Everything in the tune is spot on and runs mint just think this cam should pull and go past 6100ish. Right now my Accel Black Top 30#s are sitting at 86-88% WOT.
If anything that's rich. You could lean it out and probably pick up some power. 80s for idc is not bad, it's just not ideal.
You're injectors flow plenty. Lean out the tune to see if you get any gains.
