General Maintenance & Repairs - Ac hot in traffic, ice cold at night and startup
GulfCoastWS6
07-11-2011, 10:30 PM
My A/c blows warm or room temp on a hot day in traffic, but is ice cold at night or moving along pretty good. Is this just b/c the car is hot or do I have a problem?
wssix99
07-12-2011, 08:57 AM
If it works when the outside air is cool and doesn't when the outside air is warm, its probably because the system is low on freon, your radiator/condenser is covered in roadkill or other garbage, or the radiator fans aren't working.
The easy thing to start with is cleaning the radiator and condenser.
GulfCoastWS6
07-12-2011, 09:21 AM
The fan kicks on, I'll look for garbage. I thought if it was low on freon it would be warm all the time, but I'll take your word for that as I don't know much about A/C components. Thanks
99redrockett/a
07-12-2011, 11:40 AM
Sounds like poor condenser air flow to me, make sure there's nothing blocking the condensers airflow
LS6427
07-12-2011, 10:20 PM
You have a dirty condensor.......the outside of it. Read this thread......The only thing I recommend you differently is remove it and have it cleaned at a shop or do it yourself. Worry about recharging the 134 refrigerant afterwards.
http://www.ls1tech.com/forums/general-maintenance-repairs/1036302-if-you-run-hotter-when-you-turn-c-city-driving-probably-why.html?highlight=condensor
GulfCoastWS6
07-13-2011, 01:50 AM
Super helpful... I'm about to put a lid and tb and all that on my car anyways so I'll just do this all at the same time. THANKS
wssix99
07-13-2011, 08:33 AM
Its unlikely that its freon related but the system's ability to cool the freon is a function of temperature and quantity of airflow over the condenser. If the freon level is low, the cooler temperatures at night could be enough to get it to an adequate level.
GulfCoastWS6
07-13-2011, 10:53 AM
I'm betting its the condenser, I havent had a chance to check. That write up about taking it out and cleaning it should be a sticky in general maintenance if it isn't.
2000 TAWS6
07-13-2011, 11:53 AM
When I got my car I found a Publix plastic bags was sucked into each of the fans. They spun, but they worked much better after removing the bags.
wssix99
07-13-2011, 03:28 PM
+1 I found some sort of dead rodent/thing plastered to mine when I did my cleaning.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
