Installing Torque Converter
I am going to be installing a torque converter in the near future, and have a couple questions. I've heard that you should always do a tranny cooler when doing this, which makes sence. I've just read a couple of posts hear that say you need to do a shift kit also. Is this accurate? I'm pretty sure I can do the TC myself, but not too sure about the shift kit. How involved is it? Also anyone got a link to a good install page for the TC?
'01 SS lots of bolt ons, cam a TC coming soon
well a cooler is'nt a necessity, just cheap insurance- Unless it has a Super high stall that will generate a lot of heat. I'd say tackle the tc install first. Make sure new tc is Seated ALL THE WAY before putting back in. Try and borrow a tranny jack plate too. THen after you have the tc all wrapped up, do the cooler, be 100% sure that it doesnt leak too!
replace the round seal at the back of the tranny when the drive shaft is out, or you'll prolly see some fluid leak there.
I'd SEARCH archives here and ls1.com fer how to's/tq specs etc. its a real handfull!
opinion --> DONT DO A SHIFT KIT. tranny builders say its just overtaxing parts beyond they're design capacities. But some owners lov em(?) Really you oughta get ls1 edit and firm shifting that way. My shifting gets firmer as I add more throttle, which is the effect you want
And i'm not just beating up stock tranny parts. And a shift kit can be a lot to install!!
good luck
good luck
Mike at Yank recommended a shift kit on the lowest setting for me. I have the SY 3500. I also put the tranny cooler in. I wanted the extra insurance, that and I live in Florida. Next will be the programming.
Originally Posted by 99ssleeper
I heard the TransGo kits arent too tough to install and that they are better than the tuning by line pressure/shift time...
I planned to order the TransGo kit for mine, but leave it to he internet to change my mind at the last minute!
The TRANSGO kit is easily one of the most time consuming/difficult shift kits you can buy from what I hear.
ALmost everyone recommends having a trans-pro install it.
Originally Posted by calongo_SS
I have the HPP3, so I can stiffen up shifts that way, my question is will the shift kit reduce or increase wear on my tranny? I have heard both things, wondering if anyone has any insight.
I installed my Transgo myself and had never worked on a a4 in my life. To look at it it was alot but once you started it really wasnt that bad. I say try it if you are up to it.
