Oil pressure sensor for wideband, any way to read voltage vs. psi?
Old 07-14-2011, 09:36 AM
dville_gt's Avatar
Default Oil pressure sensor for wideband, any way to read voltage vs. psi?
Trying to use the oil pressure input on the 2003 Express Van PCM to log a LC-1 wideband. It works, but the problem I am having is that the PCM reads psi not voltage for the oil pressure so I am having to guesstimate what to divide the reading by to get voltage.
Anyone either know how to change this to voltage or know what the output of the factory oil pressure sender is per volt? After playing with it for a while it seems like it is about 25psi per volt but I don't think that is exact.
Old 07-14-2011, 10:52 AM
joecar's Avatar
What scanner/logger are you using...?
Old 07-15-2011, 11:15 AM
dville_gt's Avatar
HP Tuners
Old 07-15-2011, 11:25 AM
OnyxY2KSS's Avatar
Do you have a voltmeter? Couldn't you just read the PSI PID in HPTuners and then read the line voltage with a meter and compare the two? Sorry if I don't fully understand the situation, you've got a real Frankenstein setup there, good luck
Old 07-15-2011, 11:42 AM
joecar's Avatar
There should be a pid named EOP in volts.
Quick Reply: Oil pressure sensor for wideband, any way to read voltage vs. psi?
