LS1T56FTW
07-14-2011, 10:11 AM
I currently have the power and ground ran for my Frost shift light. I would like to get the signal from a coil, rather than the PCM (just my preference). Anyone have any pictures of what wire they got the signal from? That would make my life a lot easier. Thanks!
LS1T56FTW
07-16-2011, 03:33 PM
Bump. Someone has to have something!
Black96z28
07-16-2011, 03:38 PM
it would be a lot easier to use the tach signal from the pcm. why is it that you don't want to? Besides, you would have to wire it to get pulses from all 8 coils to make the light work correctly.
RsSean
07-16-2011, 04:27 PM
You can tap into the coil harness off the right side bank. If you call Nitro dave they will tell you the correct wire to tap into off the coil connector.
