Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
HELP V wont start
Old 07-14-2011, 08:30 PM
ssblackss00's Avatar
Default HELP V wont start
So went to go to work yesterday and the car would not start put the key in everything came on turn to start and nothing. just a note the battery died on me 2 weeks ago got a jump and car has started ok.
Removed the battery and put the volt meter on it shows 12.XXv
the volts on the nav show 8-10v gauges are dimm nav flickering now
tied jumping it nothing..........., charging it nothing.... dont even here the starter solenoid clicking
note sure if related or not though getting some codes listed here
P1516 not sure what these 2 are exactly some thing with throttle
P2108
U0107 Lost Communication with throttle actuator control module
Any help is greatly appreciated.
Old 07-19-2011, 01:09 AM
ecotec88fiero's Avatar
Just cause the battery's voltage is 12V doesnt mean it has enough amperage to turn the motor over.
Load test it and make sure its ok.
The TAC codes will set when the battery has died.
Old 07-19-2011, 01:34 AM
itsslow98's Avatar
Replace the battery and be done with it.
Old 07-19-2011, 01:43 AM
babrown18's Avatar
Yup get a optima
Old 07-19-2011, 02:05 AM
mitchntx's Avatar
That tells me that it's something other than the battery.
If you've attached a known source of 13V to the system and you don;t hear anything happen at the starter and all electrical works, then it's the starter.
https://ls1tech.com/forums/cadillac-...art-issue.html
Quick Reply: HELP V wont start
