Small Block & Big Block Chevy Specific - Sbc 350 tbi help!
View Full Version : Sbc 350 tbi help!
EnragedHawk
07-14-2011, 09:34 PM
Ok, I'm new here. I've been using the H.A.M.B. because I'm more of a hot rodder, but it turns out my 350 TBI is too "nontraditional" for them to help me out.
So, here's my problem. I have a 1990 Chevy 350 TBI engine that I have put into a 1955 Chevy Panel Truck, and I think I'm having trouble with the computer. I have been searching all over google to figure this out, but have had no luck. Here's what's going on:
The engine cranks and has spark. I can force the engine to fire up by dumping fuel into the throttle body. Currently, my injectors are not firing. I have 12+ on one side of each injector, but I do not get the - pulse from the ECM. I can jump the wires at the ECM and force the injectors to fire, so I know there's nothing wrong with them.
So, from what I can tell, either my ECM is bad, or it's not receiving the signal it needs to fire the injectors. I have thought that it may be the pick-up coil, but I don't know how to test for that.
ANY HELP WOULD BE AWESOME!
87silverbullet
07-15-2011, 03:32 PM
Is the pcm grounded? The pcm needs ground to give ground to feed circuits.
Check your ignition module also. They are cheap and easy to change.
LilJayV10
07-20-2011, 07:21 PM
Do you know if the ECM has VATS or not? The pick up coil and the module work together to fire the injectors if I remember right.
