Help with A/C not staying on
Old 07-15-2011, 08:05 AM
Twotonefreak's Avatar
Default Help with A/C not staying on
Alright guys, here's my problem.
02 Z0, decent sized cam, A&A kit with YSi. The a/c is charged to appropriate levels. Idle's at 800. Whenever the car is idling and you turn the a/c on it, it kicks on for a second then instantly turns off. If you hold the rpms above 1,100 the air will stay on. While cruising the air stays on just fines. We've raised the rpm values, played with the tq bump or whatever that parameter is to no avail. Or if its idling and you click the a/c on, it comes on then turns right off, but as you blip the throttle to over 1100 it comes right back on.
Some of you more advanced tuning junkies please help.
Old 07-15-2011, 08:08 AM
Old Geezer's Avatar
What's the TPS enable/disable set to in the .tun ???
Old 07-15-2011, 08:19 AM
I don't have the lap top here at work with me.
What should it be set to?
Old 07-15-2011, 08:49 AM
Black96z28's Avatar
+1, or faulty pressure switch/signal wire.
Old 07-15-2011, 09:27 AM
But if it were a psi switch, then how is it working when the idle is above 1100? Wouldn't it still kick off with a bad switch?
Old 07-15-2011, 11:09 AM
Moderator
jimmyblue's Avatar
Unstable idle disables the A/C, part of the "stall saver
strategy". Try disabling that (or cleaning up idle bounce).
Old 07-15-2011, 12:38 PM
The idle is VERY stable and does not bounce around normally.
I'll have my tuner look into that. Thanks for the info.
Old 07-15-2011, 05:21 PM
Thank you very much for the input sir. My tuner disabled the "stall saver" and that worked perfectly! I owe you a cold one
Oh and Bill at HP Tuner's response to the same question. This is the first time we've heard of this issue.
