Voltage goes up and down? WHY!?
Old 07-15-2011, 11:19 PM
ritchie1791's Avatar
Default Voltage goes up and down? WHY!?
i bought a new alternator with voltage regulator, new battery and my voltage drops greatly with signal lights and a/c or cruise control. why does it do that?
Old 07-16-2011, 08:56 PM
sjsingle1's Avatar
crappy reman.......welcome to the club
Old 07-16-2011, 08:57 PM
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...-failures.html
Old 07-17-2011, 07:29 PM
cookba's Avatar
have your battery checked. and do the big 3. and have that alternator checked as well.
Old 07-17-2011, 08:00 PM
So bigger gauge wire is a good thing?
Old 07-18-2011, 10:19 AM
cookba's Avatar
yes bigger gauge wires for the Big 3 is better, use 0/1 or 4AWG. sometimes just doing the big 3 will correct a bad ground or replace a chewed up wire which may be causing your issues.
Old 07-18-2011, 05:43 PM
Oh tight I might just do that. and the wires do look kinda thin....
Old 07-18-2011, 06:48 PM
Save the manuals!
wssix99's Avatar
I learned a long time ago to never ever ever buy a reman alternator. Just not worth saving the extra $15.
Old 07-19-2011, 12:24 AM
sjsingle1's Avatar
but no one makes a NEW alt.........well........almost no one.........
https://ls1tech.com/forums/generatio...lternator.html
Old 07-19-2011, 03:52 AM
01ssreda4's Avatar
Bad connection causing a bottleneck.
Old 07-19-2011, 04:17 PM
cookba's Avatar
i am having the same issue. i have replaced the alternator with a quality piece not a crappy vautozone one, replaced the battery and double checked all bolts are fastened down. dont know whats going on. it randomly goes from mid 13v's into the low 12's. cranks up in the morning at 14.2'ish
Old 07-20-2011, 05:08 AM
Save the manuals!
wssix99's Avatar
You could take it back to Autozone and have it tested. If its bad, I'd expect they would return it and upgrade for a Gold model. I understand that the Gold alternators use all new components. I've gone "gold" on other cars and not had a problem.
If the alternator tests out good, you might have an exciter wire problem.
Old 07-20-2011, 11:12 AM
cookba's Avatar
mine is not an autozone alt. its a purpose built alternator and is tested good. the exciter wire is actually new since i stripped it when i replaced the alternator when i was having this same issue.
Ive also been told voltage fluctuating can be caused by a high speed fan signal malfunction, which i am looking into.
Old 07-20-2011, 11:32 AM
Save the manuals!
wssix99's Avatar
Ok. If the problem started after your alternator and battery install - its most likely to be something in that system. If your alternator and battery test out good, then I'd go back to the exciter install and make sure its tight.
Old 07-20-2011, 12:16 PM
SparkyJJO's Avatar
Guess I got lucky. Mine worked perfectly in my Camaro.
Old 07-20-2011, 12:22 PM
cookba's Avatar
nope problem was before new alt and battery install and is still a problem with a brand new alt and battery. all connections for the 4 pin (1 wire) cable are tight and the bolt on the back of the alternator is tight. nothing else on the car has been changed before or after this started.
Old 07-20-2011, 05:47 PM
Save the manuals!
wssix99's Avatar
What kind of aftermarket electrical accessories do you have on the car?
Have you also checked the indicators on the tensioner to make sure your serpentine belt isn't stretched out? Also, have you matched the belt routing to the sticker on the driver's side shock tower? (A loose belt can cause things like this.)
Quick Reply: Voltage goes up and down? WHY!?
