Guide plates?
Old 07-16-2011, 06:11 PM
Lawhead's Avatar
Default Guide plates?
On summit right now about to order my rockers arms push rods and such.
So have Ultra Pro mags in the cart I go to guide plates
Comp makes them and they are 20 bucks
Then trick flow makes a set that are 50
My car has the CC306 so nothing extreme at all about the cam so just get the comp or get the trick flows???
Old 07-16-2011, 06:23 PM
shbox's Avatar
The Comps aren't accurate for the LT1. Get the Trickflows ( 30400623-8). They are $26-not $50. I assume you are getting NSA rockers.
Old 07-16-2011, 06:29 PM
Lawhead's Avatar
Yes I am the Ultra Pro mags
and alright added to the cart!!! now Trickflow push rods and ARP studs!!
Old 07-16-2011, 06:44 PM
BALLSS's Avatar
the ISKY adjustables work very well on LT1 heads....
Old 07-16-2011, 07:42 PM
shbox's Avatar
You did not answer the question. UPMs come in SA or NSA.
Old 07-16-2011, 07:54 PM
Lawhead's Avatar
Actually got caught right before I bought the Ultras and Speed Density Sold me a set of the Pro mags but they are 7/16 NSA thats why I would need guide plates.
http://www.summitracing.com/parts/TFS-21407200/
and these push rods be good??
That then patriot gold kit and I should have the car back together ASAP
Old 07-17-2011, 09:38 AM
Village Troll
SS RRR's Avatar
7.2 PR's will most likely work just fine, however it would still be a good idea to take a PR you have now (I assume the ones you have now are 7.2"?) and measure the sweep before buying new stock length ones.
Old 07-17-2011, 11:22 AM
Lawhead's Avatar
I used the stock ones out of my parts car and compared them to the ones that were in the car and they were the same length I have everything ordered other then the springs I guess you can't order them straight through the internet they have to call and such???
Figured the 21st century they would be able to just do everything over the net....
Old 07-17-2011, 12:07 PM
Village Troll
SS RRR's Avatar
What I'm saying is you need to check the sweep angle:
http://www.camaroz28.com/forums/show...55&postcount=2
Old 07-17-2011, 12:23 PM
Lawhead's Avatar
ohhh I gotcha I'll check that out once all the parts get here
list of parts are
Patriot Gold Dual spring kit
Trick Flow guide plates
Trick Flow push rods
ARP 7/16 studs
Comp Pro Mags
Will all be here next week and hopefully next weekend installed. Ive heard you can swap springs with out even adding pressure to the cylinders and just letting the valve sit on the pistons. this Correct?????
Old 07-17-2011, 12:46 PM
Village Troll
SS RRR's Avatar
I have never had luck with doing it that way. The valve would sink too far down into the cylinder for the keepers to come loose. I've always had luck stuffing rope into the cylinder before knocking the keepers loose.
Hopefully you are also going to check the spring install height when replacing them. You need to add a spring micrometer and shims to that grocery list if you don't have them already.
Old 07-17-2011, 12:51 PM
Lawhead's Avatar
Install height changes from spring to spring???? figured with a brand new set they should all be good? If not guess I'll get them as well.
Old 07-17-2011, 01:04 PM
Village Troll
SS RRR's Avatar
Different brands? Perhaps. Same brand? Probably not, however it's just a good idea to check the install height to ensure the valves have the proper spring pressures.
Old 07-17-2011, 01:52 PM
BALLSS's Avatar
what spec are on the Patriot springs for "installed" height??? 1.8"?
stock are 1.700"-1.750" so a 1.8" spring would install "shorter" meaning its seat and open spring pressure would be higher.
spring pocket is machined down to allow springs with a higher install height. This requires the heads be pulled
with that said many do run 1.8" springs shorter...doubt you would be using shims
A PR check tool and spring height tool would be a good investment
Old 07-17-2011, 02:00 PM
Lawhead's Avatar
Patriot puts on their website there is no need for machining
Old 07-17-2011, 02:23 PM
gregrob's Avatar
TDC works just fine for someone competent. You should check the install height of the springs to be safe. Close to .050 under coil bind is ideal if you're not really pushing the limits of the spring.
Old 07-17-2011, 02:25 PM
Lawhead's Avatar
good for .650 and the CC306 is NOOOO where close to that lol
Old 07-17-2011, 03:14 PM
bowtiedad_z28's Avatar
You can get the patriot springs w/ free shipping here.
http://www.byunspeed.com/index.php?cPath=2902_359_453
Old 07-17-2011, 03:28 PM
Lawhead's Avatar
ahhhh I already ordered them through Thunder Racing
Old 07-18-2011, 07:28 PM
diablizzard's Avatar
Did they widen the seperation of the valves and studs on the LT1? I just started to put the valve train together on mine, and I noticed some of the rockers were not on straight. I currently have the comp cam guide plates intalled, and obviously need to replace them.
Quick Reply: Guide plates?
