Need some help really bad lt1 350
my car misfire when i take off around 1400 rpm i have changed the opti spark plugs and wire and the coil pack can anybody point me somewhere cause she is killing me and i lost some power any ideals
A better description woulda gotten a few replies by now, so I will go ahead and nibble to try and get it somewhere.
When does it misss, does it only miss at take off, all the time, when its warm, cold? How many miles are on it? Does it still have cats?
What brand opti?Any codes? Have you checked it at night in th edark under the hood to see if there is any arcing? Any burnt wires? Did you chnage your 02's out after you heat cycled the headers?
That should give us an idea......
sorry for the delay, had the motor rebulit 16 months ago have 30lbs ford injectors no cats no codes and back fire all the time and i just changed the plugs and wire and they're not touching the headers 152xxx but rebuild
