Custom Head Gaskets??????
Old 07-17-2011, 12:07 PM
joelster's Avatar
Default Custom Head Gaskets??????
Anyone know who to go with? Also what is the turnaround time and price you paid? I need something right around .080" compressed thickness.
Old 07-17-2011, 12:18 PM
97pontta's Avatar
I went with a Cometic MLS gasket for my 355 build. You can choose the gasket bore ID as well as thickness. They make each gasket to order and took mine about a week from ordering to show up with UPS ground shipping. Cost was $190 shipped for the pair.
Old 07-17-2011, 12:50 PM
gregrob's Avatar
Fly cut
Old 07-17-2011, 02:27 PM
joelster's Avatar
Originally Posted by gregrob
Fly cut
I thought about that but I have 2 problems.
1. The pistons have a real nice coated top to them, so fly cutting would go right through it. They are Mahle's.
2. The fly cutting tools cost a lot more than a set of gaskets.
Unless you know where to get an 8mm stem fly cutting tool for a 2.10" valve for cheap?
Old 07-17-2011, 02:31 PM
gregrob's Avatar
What about retarding the cam a little? The only gaskets I found that thick were SCE copper which would require o rings.
You can call cometic and ask about custom ones.
There is a post about LS fly cutting tools on here ill look for it
Old 07-17-2011, 02:37 PM
gregrob's Avatar
https://ls1tech.com/forums/generatio...ing-tools.html
http://www.lindytools.com/inheadpiston.html
~100 bones
joelster's Avatar
The pistons are out of the hole .023". The cam is ground on a 105 LSA. With it installed straight up with a gasket that is .049", the exhaust ptv is .045ish and the intake is .060ish. I advanced the cam 4 degrees to help the exhaust out (and it did) but then the intake valves hit. I doubled up the shitty Fel-pro gaskets that came with the gasket kit just to see how much it would open up the ptv clearance and it helped immensely. I was running the lash a little tight at .018".
