Sponsored by: DashLynx
dzus nightmare sunoco extended
Old 07-17-2011, 12:41 PM
bigpapi211's Avatar
Default dzus nightmare sunoco extended
i dunno wtf im doing wrong but i cant get the fastner to grab the spring. its to short. im using a #6 .375 tall spring. am i supposed to shave the side lip of the hood to get it to come down. even with that i feel it wont grab. any help from anyone dealing with this type of hood is appreciated.
Old 07-17-2011, 03:24 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had the same issue with mine. I ended up compressing the spring on the mounting tab and it's been fine
Old 07-19-2011, 07:10 PM
bigpapi211's Avatar
Just ordered the two shortest springs .225 and the .275 so well see what I can get done this weekend
Old 07-21-2011, 11:07 AM
foggedz's Avatar
X2, I had to put all of my springs in a vice and smash them down flat.
Old 07-21-2011, 11:29 AM
Cheeks's Avatar
I did the exact same thing and it worked fine
Old 07-21-2011, 05:32 PM
LS1CMR's Avatar
im not using the extended hood but i hand made my dzus rails, ill go take a quick pic and post it
Old 07-21-2011, 05:52 PM
LS1CMR's Avatar
here are some pics , i used all the same size , im pretty sure the same length you are using.
Attached Thumbnails dzus nightmare sunoco extended-phone-226.jpg   dzus nightmare sunoco extended-phone-231.jpg   dzus nightmare sunoco extended-phone-232.jpg   dzus nightmare sunoco extended-phone-227.jpg   dzus nightmare sunoco extended-phone-228.jpg
Old 07-21-2011, 08:18 PM
bigpapi211's Avatar
nice setup. did you have to flatten the springs as well, seems to be the pattern. i got everything else done but getting these damn things to grab. i get the new springs tommo. then im going to flatten them all and see which works best and post it up.
Old 07-22-2011, 10:16 PM
wlsmoku's Avatar
I shaved the lip and used .500 springs and it works like a charm
Old 07-24-2011, 09:47 AM
BADD SS's Avatar
Dan, .500 and shave the edge to almost flat, if not it could get stuck in the rail gap...
Old 07-24-2011, 10:46 AM
studderin's Avatar
https://ls1tech.com/forums/11270529-post47.html
Originally Posted by mad_steve View Post
Now, if you call Racecraft.. just tell them you want a dzus hardware kit. They should be able to get a goody bag together for you, and it shouldn't be much more than 50 or 60 bucks.
Originally Posted by studderin
Oh ya, I called and you can get everything from them. Same time you get the rails and save on shipping. They know what parts work good for there rails. The PN are
200112- the self ejust Dzus (I needed 12, normal non windseild hood)
200116- dzus springs (12)
200135- the rivits for the Dzus and the springs to the rails.
Old 07-24-2011, 06:54 PM
bigpapi211's Avatar
there exact package they orig sent me just didnt work. ended up flattening .225 and some of the tabs started out flush on mock up but when riveted they got all cocked when tightened. im just annoyed but whatever got it done got 3 fudged up tabs.
badss i didnt shave the lip. maybe i should've. it doesnt get caught anywhere it sits on the metal railing itself. drove it around today for bout 30 miles at around 90-100. everything seems fine. the front ones are the best they hold it down so much. i still gotta do the rear part. another day though, i dont have the patience for all this.
Old 07-24-2011, 06:58 PM
bigpapi211's Avatar
next time im feeling frisky on something ima just it to voight.
Quick Reply: dzus nightmare sunoco extended
