show me your accessory drive routing/setup for alt crank & wp only.....
Yes i did some searching and still need a straight answer/pics...
I will be using F body waterpump, balancer and preferably low mount alternator setup,
tell/show me how you routed it and belt part number, so I can get it set up right the first time!
also probably going to get the adjustable billet tensioner
THANKS!
THANKS!
Location: Your girl's back door giving her the long stroke while you're at work
This is exactly how mine is setup, I'm also running a Katech tensioner. There are some pics of it in a couple threads in the External section
https://ls1tech.com/forums/10685886-post7.html
perfect, thanks!!! not sure if I can mount all of the bolts for the alt bracket on the block i will be using I believe is like the Lq4 I was going to use, but I think you can get away with 2 bolts?
Does anyone else thing the p/s delete belt routing, doesn't put much belt contact with the crank or water pump pulleys. Anyone experience belt slip issues with this?
I think I've seen your car at a cruise-in, in wheelersburg before.
If no one is having belt slip issues, then it must not be that crucial, which te alternator isn't going to put nearly as much strain on the accessory drive as a p/s pump would.
I know how my belt is getting routed now!
