Western Members CA, AZ, NV, UT, CO, NM, HI
LT1 shops in LA area
Old 07-17-2011, 04:27 PM
henry172's Avatar
Default LT1 shops in LA area
I am looking for a good shop in the LA area to check out my 1997 TA; would like a shop that knows there way around lt1s. I just built a 355 with le1 heads, lt4 hot cam and full boltons; but I can not get it to run 100% correct. I have no idea what is going on; I have tried everything, I even installed a LTCC ignition system with 8 ls2 coils.
Old 07-17-2011, 06:51 PM
ZSS2148's Avatar
What's the problem.
Old 07-17-2011, 07:46 PM
henry172's Avatar
The car is running rough at idle and I am sure it will have a problem in the higher rpm's also; it shakes at idle a lot, it just is not running correctly. The idle will also fluctuate up and down at idle, but there is no codes showing.
Old 07-17-2011, 08:33 PM
ZSS2148's Avatar
Who tuned it and Are you running larger injectors? Pm if you need a place to take it for diagnosing.
Old 07-17-2011, 09:03 PM
henry172's Avatar
I am running ford svo 30lb injectors and it was tuned by PCMforless.com; mail order of course.
Old 07-17-2011, 10:43 PM
IT_SS's Avatar
sounds like you need to get a proper dyno tune
Old 07-17-2011, 11:37 PM
henry172's Avatar
^Maybe but it seems to be too far off for it to just be the tune though; It really runs like crap at idle. With all of the mods that are done it is possible the tune is off but I am not sure if it would make it run this bad. If I quickly hit the throttle at idle in park the motor will act as if I hit it then hit it again like a lazy woo....woo instead of just a single quick and solid woo!
Old 07-19-2011, 12:23 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
do yourself a favor and swap to a ls1 computer setup.... problem solved
Old 07-19-2011, 03:25 PM
henry172's Avatar
^Ryne do you honestly believe that will fix my problem. I really thought about doing the efi 24x system before I got my LTCC system, but I hear I will have problems with smog and it is more of a pain to install the 24x system.
Old 07-22-2011, 12:16 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
24x system is easy to install and tune... smog goes your going to need a find smog friendly tech, the car will run cleaner then it does on the lt1 computer... it will fix your issues for sure, LTCC in my opinion is a bandaid fix to a crap ignition system....
Old 07-22-2011, 01:53 PM
henry172's Avatar
The only pain in the butt part is going to be installing the reluctor ring, but if that will solve my problem then I guess I have to buy the 24x system. After I install everything I would like to have you tune the car for me; it is going to take a while because i am going to send the harness out to be reworked for the ls1 pcm.
Old 07-23-2011, 07:47 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
reluctor ring is easy to install... it simply replaces the factory obd2 lt1 misfire reluctor ring, behind the timing cover.... then you just use a crank sensor out of a 99ish chevy van (i believe), bolts right up in place of the factory lt1 sensor
Old 07-24-2011, 10:09 PM
henry172's Avatar
^ Ya but getting that timing cover off and on without having a oil leak is going to be a pain. I just need to be sure to drop the oil pan enough to get the gasket out from the timing cover. That is the only pat of the job that may give me a problem.
Quick Reply: LT1 shops in LA area
